Paint.
For works-in-progress. This is the place to upload things that aren't done yet, or tech demos of specific systems or technologies.
This is the only download category to upload works in progress of your application or game.
Paint.
(this has since been promoted to a non-WIP version: viewtopic.php?t=7252 )
badmai
Re: Paint.
Post by badmai »
Think it needs a crosshair on the painting screen, and zoom could be a sprite that magnifies whats under cursor and follows.
Re: Paint.
Good suggestions!
Re: Paint.
Updated with a new version that fixed the drawing tools.
Re: Paint.
Updated with a version that loads and saves in the new BMX bitmap file format.
Re: Paint.
Update:
- fixed a faulty offset in the file header when saving BMX files
- palette and tool menus now in a separate screen for visibility
- holding down CTRL will display mouse coordinates and active draw mode
Re: Paint.
Decided to no longer call this a Work In Progress program, version 1.0 has been released in the graphics applications section: viewtopic.php?t=7252
(it adds the ability to load and save color palettes distinctly from images)
