New audio upload: Music Player Library for BASIC Programs
DusanStrakl
Post by DusanStrakl »
View File
I wrote a library to enable BASIC programs play music in the background.
It is compatible with Simplest Effects Sound library I released a while ago.
To demo the library I included two BASIC programs:
PLAY.BAS - Playing Twinkle Twinkle Little Star - it demonstrates the BASIC program doing other stuff including calling simple Effects
HOUSE.BAS - Playing House of the Rising Sun - it demonstrates a bit more complex music
Full Tutorial and source code is available from my blog:
https://www.8bitcoding.com/p/music-player-library-for-basic-programs.html
kliepatsch
Post by kliepatsch »
Pretty cool! Very easy to use, once one read the documentation on your page.
And the example songs are a good starting point to experiment and make our own ?
I hope someone will use this for their games written in BASIC
kliepatsch
I have noticed that there seems to be a bug that the end of the song data is not used during playback.
See as an example the attached song, where I have the same four notes played twice in a row. However, only the first time, all four notes are played, whereas the second time only the first three notes are played.
Or am I doing something wrong? (Simply Ctrl+C, Ctrl+V the source into the emulator).
MYSONG.TXT
DusanStrakl
MYSONG.TXT 746 B · 4 downloads
Thank you for compliments.
You made just a minor error. You are not loading all the data to memory. 64 bytes of music plus 9 bytes of header data so you have to change the FOR loop to read total of 73 bytes.
kliepatsch
Ah silly me ?
Here's a short song made for the Music Player Library. Again simply  Ctrl+C  Ctrl+V  it into the emulator. Feel free to modify and use it everyone if you see fit.
DANDELION.TXT
DusanStrakl
Ah silly me ?
Wow, this is great tune. Can I include it on my blog (of course with full credits)? Perhaps there will be more that I could add and build a little library of songs for the player.
kliepatsch
Yes, no problem!
kliepatsch
Hi Dusan,
I've come around to trying out the possibility to create custom instruments. I am having a couple of issues.
  • The Volume setting seems to be at the position of what's called "sustain", and the "Volume" setting doesn't seem to change anything
  • For the ADSR, are the parameters doing what they should?
  • What is the additional sustain parameter supposed to do? How long continuous notes are held?
I'm utterly perplexed by the result the attached test file is giving me.
Also, in your blog you say there's 5 predefined instruments, but actually there are 6, so I guess it's only 2 free slots (but it doesn't matter since we can poke into existing ones).
Thanks in advance
Edit: To clarify what I was trying to do with that file. Basically I wanted a short, percussive envelope (an Attack-Decay envelope so-to-say). Because that wasn't turning out how I expected, I began messing around, setting the volume to 0 and making the sound "continuous" which both didn't happen.
TEST_2.TXT
DusanStrakl
Hmm this is indeed unusual result but also parameters are a bit unusual and it would require some time to debug to understand what exactly is happening.
To achieve a short percussive envelope I would use setting like this:
Triangle wave
AD = $10                          - very short attack, no decay
SR = $08                          - no sustain, medium long 200ms release
Not continuous
Max Volume = 63
Sustain Volume = 63
LR = 3                              - my documentation should state that 11 is binary for left and right channel so decimal 3, will update my post
or in code:
10 LOAD"PLAY.PRG",8,1,$9000
20 FOR N=0 TO 64+8
30 READ A
40 POKE $6000+N,A
50 NEXT N
100 REM SETUP CUSTOM INTRUMENTS
110 SYS $9006
120 M=PEEK(4)+PEEK(5)*256+6*8
130 POKE   M,128
140 POKE M+1,$10
150 POKE M+2,$08
160 POKE M+3,0
165 POKE M+4,63
170 POKE M+5,63
190 POKE M+6,3
800 REM PLAY SONG
810 POKE 2,$00
820 POKE 3,$60
830 SYS $9000
840 END
999 REM
1000 REM ===== HEADER DATA =====
1001 REM
1010 DATA 4        :REM NUMBER OF VOICES
1020 DATA 9        :REM TEMPO
1030 DATA 64,0     :REM LENGTH (16 BITS)
1040 DATA 1        :REM AUTOREPEAT ON
1049 REM
1050 REM ===== INSTRUMENTS =====
1051 REM
1060 DATA 6,0,0,0 : REM CUSTOM INSTRUMENT
1099 REM
1100 REM ===== MUSIC DATA =====
1101 REM
1110 DATA 40, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0
1120 DATA  0, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0
1130 DATA 40, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0
1140 DATA  0, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0,    0, 0, 0, 0
Please let me know if this creates the effect you were going for? I will try to find some time over the Weekend to investigate strange result your settings created.
kliepatsch
Thanks. Yes, that is giving me what I want.
I need to apologize because yesterday, I haven't properly looked at your documentation. Now I understand that the two ADSR bytes give four durations, and the sustain level parameter is the extra one. That is useful to know, and I will try again with that knowledge. But the "looping" I was observing yesterday seems to be a bug.
