Serial port
hth313
Serial port
Post by hth313 »
I wonder if there is a serial port planned for the Commander X16? It does not seem so from what I have seen, but maybe there is something for the expansion bus?
The main reason that I want a serial port is for remote debugging.
Serial port
We have actually had several conversations about the serial port, at this point.
Short version: the last we were told, there's going to be a "User" port that will likely have a DB25 jack connected. This will work almost exactly like the Commodore 64's User port, with a likely top speed of 19200 bps.
There seem to be no plans for a 16550 (PC) or 6551 (Commodore, Apple) UARTs. The reasons are varied, but to sum up all of the discussions - the team just does not feel either is a priority.
Perifractic
Serial port
Post by Perifractic »
Sorry there's no serial port.
smartroad
Serial port
Post by smartroad »
Opportunity to add one via expansion slots?
mobluse
Serial port
Post by mobluse »
I think it should be standardized how a serial port is connected and used from software even if it isn't connected from start.
Cyber
Serial port
Post by Cyber »
If it will be demanded, a popular expansion card will appear, which might become close to standard.
Just like with Commodore expansion cartridges: despite being third party, some of them were very popular, and many users had same cartridges. From practical point of view it was sort of standard.
lamb-duh
Serial port
Post by lamb-duh »
there's an ongoing discussion about that, serial ports would be accessed using chrin and chrout (and the kernel routines that go along with them).
