GOAL: User selects MP4 or other Video file, chooses a few parameters --> program outputs a Video .A file and a soundtrack .ZCM file AND a .PRG file for play on the X16
CURRENT STATE: Output of .A file is 50% complete. Program outputs .A file in 8 bpp frames in either 192x128 or 160x112 in user chosen frame rate. (not all frame rates play successfully. Max is 10fps for 160x112 and I'm trying to push 7fps in 192x128 (6fps is pretty solid) TODO ON VIDEO: Implement 4bpp output which will be able to play at 15fps (or 12 fps for the higher resolution). Audio processing must be done separately PRG must be done separately.
I will not be posting this piece of software until I get 4bpp video output implemented which is pretty soon. I will provide snapshot on request to anyone who wish's to do something with Video on the X16 or just want's to play. The video conversion is pretty straightforward and the Audio processing and PRG editing is not to advanced. (Audio processing does require a little math to get the Audio file correct for A/V sync.) I'll will be happy to walk through the steps for using my software. DM me or contact me on the X16 Discord Tony3068
In the meantime here's some samples of Work I've done with X16 video conversion.
GORILLAZ RHINE VIDEO
viewtopic.php?p=35485#p35485
BAD APPLE DEMO
viewtopic.php?p=34411#p34411
SKELLY
viewtopic.php?p=34974#p34974
RABBIT STUFF
BOUNDIN (Pixar Short) (Ok it's a JackAlope but that's close to a Rabbit)
Big Buck Bunny
https://drive.google.com/file/d/1_k536I ... sp=sharing
(This is pretty well known, If you haven't seen it yet you should)
A Tale of Peter Rabbit & Ben Bunny
https://drive.google.com/file/d/1XxpT3s ... sp=sharing
(Had to do another Rabbit one
Watership Down (1978 Animated Movie)
(YES the whole Movie !!!)
https://drive.google.com/file/d/17qHOjd ... sp=sharing
MORE VIDEO STUFF
Clint Eastwood (More Gorillaz !!) (This one is 4 bits per pixel, But I did something interesting with that)
Halloween (From the Burton Movie)
The Night Santa Went Crazy (Xmas Parody: Wierd Al, (Kind of sick & demented) )
Dumb Ways to Die (This was initially a Safety Video for Melbourne Metro)
(I am informed it is somewhat of a Meme in Australia !!)
Elephant's Dream
https://drive.google.com/file/d/14-9P23 ... sp=sharing
(A somewhat surreal Animated short)
GULLIVERS TRAVELS
https://drive.google.com/file/d/1ZRaP7x ... sp=sharing
(Another FULL MOVIE animated Circa. 1949)
The Dinosaur Life
https://drive.google.com/file/d/1BW6Fij ... sp=sharing
(Yet another Full Length Movie file)
