Commander X16 KERNAL and emulator R48
Software from 8-Bit Productions for the Commander X16.
We're proud to announce the R48 "Cadmium" release of the Commander X16 operating system and emulator.
https://github.com/X16Community/x16-emu ... es/tag/r48
Highlights include:
  • Emulated VERA SPI clock has been updated to half of the VERA clock speed rather than the CPU clock.
  • Trace for ROM banks 13-15 (x16edit and Basload) is now supported [stefan-b-jakobsson]
  • Fixed debug reads from the stack and a few unbounded values in the debugger display
  • VERA PSG: for the saw and triangle waves, the inverse of the pulse width value is XORed with the value of the wave. This is the behavior of VERA 47.0.2 on hardware. [m00dawg]
  • Allow setting the amount of RAM in the web version of the emulator [JimmyDansbo]
  • Windows 11: Rounded corners should no longer cut off the lower left and lower right of the emulator window.
  • New memory statistics feature [irmen]
  • HostFS: Implement DOS "T"ell command
  • Debugger now includes elapsed cpu clocks since the last breakpoint or step
  • 65C816: Fixed stack relative indirect address calulation wrongly using the direct page [Fulgen301]
  • 65C816: high bytes of .X and .Y are now cleared when PLP or RTI set x=1 [cnelson20]
  • 65C816: PEI no longer does improper page wraparound, [dp] indirect modes now properly read the address. [Fulgen301]
  • More changes in the ROM.
