run basterm with emulator x16?
funkheld
Post by funkheld »
hello, good day.
can you also run basterm with the emulator for x16?
thanks.
greetings
REM V* - JUNE 2024
SERIAL.IN = 0 : REM DEFINE THIS FIRST FOR PERFORMANCE
SCREEN 1 : REM 80 COL, IF YOUR EYES CAN HANDLE IT
REM SCREEN 3 : REM 40 COL, IF FLAT SCREEN OR CAN ADJUST THE EDGES
REM SCREEN 9 : REM 64 COL, BUT NICE FOR SORT-OF 40-COL ON A CRT OR COMPOSITE
REM PRINT CHR$($0F) : REM ENABLE ISO-MODE (USE THIS IF CONNECTING TO ASCII/IBM THINGS)
PRINT CHR$($0E) : REM UPPER/LOWER PETSCII (USE IF CONNECTING TO COMMODORE/PARTICLES BBS)
COLOR 1,0
CLS
DIM BAUD.DIV.HI(22)
DIM BAUD.DIV.LO(22)
DIM BAUD.RATE$(22)
RESTORE BAUD.DIVS
FOR I = 1 TO 22
  READ HI:READ LO:READ RATE$
  BAUD.DIV.HI(I) = HI
  BAUD.DIV.LO(I) = LO
  BAUD.RATE$(I) = RATE$
NEXT I
BAUD.CURR = 9 : REM DEFAULT TO 2400 BAUD
SERIAL.REG.BASE = $9FE0 : REM DEFAULT IO7 LOW (ADJUST AS NEEDED)
REM WHEN DLAB==0 (BIT 7 OF REG.BASE+3)
REM --------------------
REG.READ.RBR = SERIAL.REG.BASE+0
REM REG.READ.IER = SERIAL.REG.BASE+1
REM REG.READ.IIR = SERIAL.REG.BASE+2
REG.READ.LCR = SERIAL.REG.BASE+3
REM REG.READ.MCR = SERIAL.REG.BASE+4
REM REG.READ.LSR = SERIAL.REG.BASE+5
REM REG.READ.MSR = SERIAL.REG.BASE+6
REM REG.READ.SCR = SERIAL.REG.BASE+7
REG.WRITE.THR = SERIAL.REG.BASE+0
REM REG.WRITE.IER = SERIAL.REG.BASE+1
REG.WRITE.FCR = SERIAL.REG.BASE+2
REG.WRITE.LCR = SERIAL.REG.BASE+3
REG.WRITE.MCR = SERIAL.REG.BASE+4
REM REG.WRITE.NA1 = SERIAL.REG.BASE+5
REG.WRITE.MSR = SERIAL.REG.BASE+6
REM REG.WRITE.SCR = SERIAL.REG.BASE+7
REM WHEN DLAB==1 (BIT 7 OF SERIAL.REG.BASE+3)
REM REG.READ.DLL = SERIAL.REG.BASE+0
REM REG.READ.DLM = SERIAL.REG.BASE+1
REM  IIR,LCR,MCR SAME
REG.WRITE.DLL = SERIAL.REG.BASE+0
REG.WRITE.DLM = SERIAL.REG.BASE+1
REM  FCR,LCR,MCR SAME
GOSUB SERIAL.INIT
LOCAL.ECHO = 0
PRINT
PRINT "(8-N-1)"
PRINT "F1: TOGGLE LOCAL ECHO (DEFAULT OFF)"
PRINT "F2: DECREASE BAUD"
PRINT "F3: INCREASE BAUD"
MAIN.LOOP:
  GET A$
  A = ASC(A$)
  IF A = 0 THEN GOTO SKIP.XMIT
  SEND=1
  IF A = 133 THEN SEND=0:LOCAL.ECHO = NOT LOCAL.ECHO : REM F1 TOGGLE LOCAL ECHO
  IF A = 137 THEN SEND=0:GOSUB DECREASE.BAUD         : REM F2 DECREASE BAUD RATE
  IF A = 134 THEN SEND=0:GOSUB INCREASE.BAUD         : REM F3 INCREASE BAUD RATE
  IF SEND=0 THEN GOTO SKIP.XMIT
  IF LOCAL.ECHO <> 0 THEN PRINT CHR$(A);
  POKE REG.WRITE.THR, A
SKIP.XMIT:
  SERIAL.IN = PEEK(REG.READ.RBR)
  IF (SERIAL.IN <> 0) THEN PRINT CHR$(SERIAL.IN);
  GOTO MAIN.LOOP
REM ****************************************************
INCREASE.BAUD:
  BAUD.CURR = BAUD.CURR+1
  IF BAUD.CURR > 22 THEN BAUD.CURR = 1
  GOSUB SERIAL.INIT
  RETURN
DECREASE.BAUD:
  BAUD.CURR = BAUD.CURR-1
  IF BAUD.CURR < 1 THEN BAUD.CURR = 22
  GOSUB SERIAL.INIT
  RETURN
SERIAL.INIT:
  POKE REG.WRITE.LCR,$83 : REM SET DLAB==1 (AND SET 8 DATA BIT, 1 STOP BIT)
  POKE REG.WRITE.DLL,BAUD.DIV.LO(BAUD.CURR) : REM LSB (LO)
  POKE REG.WRITE.DLM,BAUD.DIV.HI(BAUD.CURR) : REM MSB (HI)
  POKE REG.WRITE.FCR,$C1 : REM 14 BYTE FIFO, ENABLE FIFO
  A$ = "(" + BAUD.RATE$(BAUD.CURR) + ")"
  PRINT A$;
  X = PEEK(REG.READ.LCR) : REM STORE CURRENT BIT MASK
  X = X AND $7F          : REM SET DLAB == 0
  POKE REG.WRITE.LCR, X
  X = $02 : REM SET RTS BIT 1    0000 0010
  POKE REG.WRITE.MCR, X
  X = $20 : REM SET DSR BIT 5    0010 0000
  POKE REG.WRITE.MSR, X
  RETURN
BAUD.DIVS:
DATA $48,$00,"    50":REM  1 50
DATA $20,$BA,"   110":REM  2 110
DATA $0C,$00,"   300":REM  3 300
DATA $08,$00,"   450":REM  4 450
DATA $06,$00,"   600":REM  5 600
DATA $04,$00,"   900":REM  6 900
DATA $03,$00,"  1200":REM  7 1200
DATA $02,$00,"  1800":REM  8 1800
DATA $01,$80,"  2400":REM  9 2400
DATA $01,$00,"  3600":REM 10 3600
DATA $00,$C0,"  4800":REM 11 4800
DATA $00,$80,"  7200":REM 12 7200
DATA $00,$60,"  9600":REM 13 9600
DATA $00,$40," 14400":REM 14 14400
DATA $00,$30," 19200":REM 15 19200
DATA $00,$20," 28800":REM 16 28800
DATA $00,$18," 38400":REM 17 38400
DATA $00,$10," 57600":REM 18 57600
DATA $00,$08,"115200":REM 19 115200
DATA $00,$04,"230400":REM 20 230400
DATA $00,$02,"460800":REM 21 460800
DATA $00,$01,"921600":REM 22 921600
Re: run basterm with emulator x16?
No. The emulator does not (yet) have a serial port connection. Until someone adds an emulated serial port, there's simply nothing for BASTERM (or ROMTERM) to talk to.
funkheld
Post by funkheld »
hello , thanks for info.
greeting
