nxtbasic : sprite spr64.raw before bild2.raw and sprite spr32.raw
funkheld
Post by funkheld »
hello, good day.
spr64.raw / spr32.raw in front of bild2.raw with nxtbasic.
greetings
'Demonstration of 3 sprites, where if they are colliding the animation speed is dropped
'and which sprites are colliding is displayed.
'Developed by Unartic, july 2024
SCREEN 128
BVLOAD "bild2.raw" ,0,0
index1 = ADDSPRITE("spr64.raw",64,64,8,0)
index2 = CLONESPRITE(index1)
index3 = CLONESPRITE(index1)
Dim vX(index3)
Dim vY(index3)
SHOWSPRITE index1,RNDINT(320),RNDINT(240),3
SHOWSPRITE index2,RNDINT(320),RNDINT(240),3
SHOWSPRITE index3,RNDINT(320),RNDINT(240),3
'Initial vectors for all three balls
vX(index1)=3
vY(index1)=3
vX(index2)=6
vY(index2)=-3
vX(index3)=-6
vY(index3)=3
Locate 0,3
PRINT "BALLS SLOW DOWN WHEN THEY OVERLAP"
PRINT " AND SHOW WHICH BALLS ARE OVERLAPPING"
Loop:
    FOR i = index1 to index3
        if SPRITEGETX(i)+vX(i)<0 THEN
            vX(i) = RNDINT(3)+1
        elseif SPRITEGETX(i)+vX(i)>256 THEN
            vX(i) = NEG(RNDINT(3))-1
        END IF
        if SPRITEGETY(i)+vY(i)<0 THEN
            vY(i) = RNDINT(3)+1
        elseif SPRITEGETY(i)+vY(i)>176 THEN
            vY(i) = NEG(RNDINT(3))-1
        END IF
        MOVESPRITE i,vX(i),vy(i)
    next i
    CollidingBalls$=""
    'SPRITECOL returns a string with ascii values for all colliding sprites
    if len(SPRITECOL(index1))>0 then
        CollidingBalls$ = STR$(index1) + " AND"
        c$ = SPRITECOL(index1)
        FOR i = 1 to len(c$)
            CollidingBalls$ = CollidingBalls$ + STR$(ASC(MID$(c$,i,1)))
        NEXT i
        sleep 10
    elseif len(SPRITECOL(index2))>0 then
        CollidingBalls$ = STR$(index2) + " AND"
        c$ = SPRITECOL(index2)
        NEXT i
        sleep 10
    elseif len(SPRITECOL(index3))>0 then
        CollidingBalls$ = STR$(index3) + " AND"
        c$ = SPRITECOL(index3)
        NEXT i
        sleep 10
    end if
    locate 25,15
    print "                                                ";
    locate 25,15
    PRINT CollidingBalls$;
goto Loop
'Demonstration of 25 sprites moving rapidly along the screen
SCREEN 128
noSprites = 25          'number of sprites to display
Dim Sprites(noSprites)  'Sprite indexes
Dim vX(noSprites)       'x-vectors
Dim vY(noSprites)       'y-vectors
'Set screen to green
'RECT 0,0,319,239,9
'Add a sprite width=32, height=32, colordepths is 8bpp, and palette offset=0, and return its index
Sprites(1) = ADDSPRITE("spr32.raw",32,32,8,0)
'Show the sprite on the screen at a random location between x(0-300) and y(0-200), in front of layer 1
ShowSprite Sprites(1),RNDINT(300),RNDINT(200),3
'Clone this sprite as much as needed
for i = 2 to noSprites
    Sprites(i) = CloneSprite(Sprites(1))
next
'Set a vector for x and y positive or negative 1 to 10 px per 'frame'
for q = 1 to noSprites
    vX(q) = RNDINT(10)+1
    if RNDINT(100)>50 THEN vX(q)=neg(vX(q))
    vY(q) = RNDINT(10)+1
    if RNDINT(100)>50 THEN vY(q)=neg(vY(q))
next
Loop:
    for i = 1 to noSprites
        'get current x and y of a sprite
        x = SpriteGetX(Sprites(i))
        y = SpriteGetY(Sprites(i))
        'check if we need to bounce left or top
        if x<16 then vX(i)=RNDINT(15)+1
        if y<16 then vY(i)=RNDINT(15)+1
        'check if we need to bounce right or bottom
        if x>304 then vX(i)=NEG(RNDINT(15)+1)
        if y>224 then vY(i)=NEG(RNDINT(15)+1)
        'move the sprite amount of pixels in vector array
        MoveSprite Sprites(i),vX(i),vY(i)
    next
Goto Loop
spr32.zip
(931 Bytes) Downloaded 42 times
spr64-bild2.zip
(5.04 KiB) Downloaded 34 times
funkheld
Re: nxtbasic : spritecolli spr64.raw before bild2.raw and many sprite spr32.raw and spr16.raw
Post by funkheld »
here ist collisprite spr16.raw
greeting
spr16.zip
(845 Bytes) Downloaded 36 times
