hallo, guten tag.
Call address: $FF4D
how can I do this in nxtbasic :
Function Name: clock_set_date_time
Purpose: Set the date and time
Call address: $FF4D
Communication registers: r0 r1 r2 r3
Preparatory routines: None
Error returns: None
Registers affected: .A .X .Y
Description: The routine clock_set_date_time sets the system's real-time-clock.
Register Contents
r0L year (1900-based)
r0H month (1-12)
r1L day (1-31)
r1H hours (0-23)
r2L minutes (0-59)
r2H seconds (0-59)
r3L jiffies (0-59)
r3H weekday (1-7)
thanks
greeting
nxtbasic : clock_set_date_time
Re: nxtbasic : clock_set_date_time
The r-registers are just memory locations:funkheld wrote: ↑Fri Jul 26, 2024 11:35 am hallo, guten tag.
Call address: $FF4D
Call address: $FF4D
Error returns: None
Register Contents
r0H month (1-12)
r1L day (1-31)
r1H hours (0-23)
r2L minutes (0-59)
r2H seconds (0-59)
r3L jiffies (0-59)
r3H weekday (1-7)
thanks
greeting
r0L= $02
r0H= $03
r1L= $04
etc
So you can set them with POKE
The processor registers can be set with:
LDA value
LDX value
LDY value
Then you can do:
SYS $FF4D
And then you can read result directly from the r-registers (if needed) and the processor registers with:
var = GETA
var = GETX
var = GETY
but....if you want the real-time-clock of the emulator to be set, you can run the emulator with the -rtc argument. This will copy the system clock into the emulated real time clock.
thank you, I'm also interested in other commands.
this was just a question about how to set this roL etc.
in nxtbasic.
greetings
in nxtbasic.
greetings
I understand. Than this is your answer ![Smile :-)](./images/smilies/icon_e_smile.gif)
POKE $02,$FF
Sets r0L to $FF
POKE $02,$FF
Sets r0L to $FF
hello tanks for demo.
greeting
greeting
