nxtBasic : first 5 lines flicker ih the screen
funkheld
Post by funkheld »
hello, good day.
I did a test.
fill the entire screen with "B".
nxtbasic is slow.
when the screen is scrolled to the right with the "E" key, the top 5 lines flicker. I fixed this with "sleep 1" in the basic of the x16.
how can I get rid of the flickering here in nxtbasic?
thanks.
greeting
SCREEN 128
gosub ascii
z=255
StartEdit:
    Loop:
        Key$=GET
        if Key$="Q" then GOSUB links
	if Key$="E" then GOSUB rechts
    Goto loop
end
links:
print " LINKS"
return
rechts:
 z=z-1
 if z=-1 then
   z=255
   u=u-1
   Poke $9F38,u
 endif
 Poke $9F37,z
return
ascii:
 For d= 1 to 8000
   VPoke 1,$b000+d+1,2
   VPoke 1,$b000+d,0*16+2
 next d
return
unartic
Re: nxtBasic : first 5 lines flicker ih the screen
Post by unartic »
Here is an example which fills the screen in a blink. I also added the left and right scrolling. The SLEEP 0 makes nxtBasic wait until the 'electronbeam' is in VBLANK, so this should prevent the filcker.
SCREEN 128
FILLSCREEN 0
gosub ascii
HScroll=0
ScrollAmount = 3
StartEdit:
    Loop:
        Key$=GET
    Goto loop
end
links:
    if HScroll>ScrollAmount then
        HScroll=HScroll-ScrollAmount
        SLEEP 0
        POKEN $9F37,CHR$(HScroll MOD 256) + CHR$(HScroll/256)
    end if
return
rechts:
    HScroll=HScroll+ScrollAmount
    SLEEP 0
return
ascii:
    line$ = SPC(256)    'this way 256 bytes are reservers, so no relocation of string space needed
    line$=""
    for i = 1 to 128
        'Build a string of 128 pairs of letter B CHR$(2) and a color byte CHR$(2)
        line$ = line$ + CHR$(2) + CHR$(2)
    next
    'VPOKE a line at a time
    For d= 0 to GETROWS()-1
        VPOKEN 1,$b000 + (d*256),line$
    next d
return
funkheld
Post by funkheld »
hello, that works wonderfully.
there is no more flickering.
the execution speed has increased.
you programmed it well, thank you.
greetings.
funkheld
Post by funkheld »
1 byte always appears at the top left.
You can see it better with cls.
I can't get rid of the byte.
Thanks.
greeting
unartic
Post by unartic »
Yes, you have to ignore that for the moment ;-)
nxtBasic uses vera fx for very fast multiplication for which the result is written to vram, currently at address $00000. I have to move it to a non-visble part of memory. I'll make sure that happens with the next release.
So for now: just ignore it, it will go away :-)
funkheld
Post by funkheld »
hello, thank you for your great help.
when I try something new at the age of 76 jahr , I always have a lot of questions.
greetings
I'd say when anybody tries anything new, they're gonna have a lot of questions.
