hello, good day.
here is an error with nxtbasic.
thanks.
greeting
STA "A" 'puts a "A" in the accumulator
SYS $FFD2 'Calls the kernal CHROUT subroutine to print the A on the screen
PRINT GETA 'as the accumulator is not changed by CHROUT, this will return the value 65
nxtBasic error with STA "A"
- fehler.jpg (79.23 KiB) Viewed 1354 times
Re: nxtBasic error with STA "A"
Hi! The documentation is incorrect.funkheld wrote: ↑Wed Jul 24, 2024 9:31 pm hello, good day.
thanks.
greeting
STA "A" should be LDA "A"
I'll correct the docs asap
hello, thanks for info.
I thought you could use this sta now too.
Could you extend this asm so that it works with sta too?
you made a great nxtBasic.
thanks.
greetings
thanks.
greetings
No, the language can't be extended; the opcodes are hardwired. Even if we could, STA A would be a useless command, "store the contents of the accumulator in the accumulator".
To load a value in the processor registers you can use:
LDA "A"
LDX "A"
LDY "A"
To retrieve a value from one of the processor registers, you get use:
var$ = GETA()
var$ = GETX()
var$ = GETY()
hello thanks for info.
greeting
greeting
If I have compiled a basic, where is the ASM program?
I would like to take a look at it, please.
Which assembler did we use to make a prg from the ASM, please?
Thanks.
Greetings
Thanks.
Greetings
The program is assembled with a custom assembler Ive developed myself (build in). If you compile with -debug option a debug folder is created in wich you’ll find the compiler steps, which includes the assembly listing.
hello, good day.
there are wonderful ASM assemblers for the x16.
why is the wheel being reinvented here?
I would have preferred to see more light in the ASM code than more secrets.
Can you recompile the asm code that you see with -debug?
thanks.
greetings
thanks.
greetings
I wanted to make sure there are no dependency's. So, just download nxtBasic and it runs. As this is a Basic language, I recon the assembly side if of little interest
It is not possible to compile files in the /debug folder.
If you want to have look at how the build in functions work, the /asm folder is your friend.
