Save it to STARTMENU.PRG or even use it as your AUTOBOOT.X16
BASLOAD "STARTMENU.BASL.TXT"
SAVE "@:STARTMENU.PRG"
Another feature in this version is that it will "auto-pick" a menu option after a counter down is expired. Let fate decide what activity you get LOADed up into And if the selection frustrates you, just CTRL+ALT+DEL and the count-down will randomly pick something else.
You'll need to modify the "LOAD.xxx" labels in the BASLOAD code to suite your particular file configuration - it's not so much "code" but "CMDR-DOS commands". So just consider this file as a template for ideas on how to setup a menu like this, and the example should be pretty straightforward to follow.
