Well, my 1st BASLOAD program thats worth sharing...
It allows you to re-map the function keys to whatever you want. 10 chars max.
Basically came about as I got tired of typing 'BASLOAD TEST.BASL' when I was doing some programming.
So have fun!
The latest will always be in GITHUB - See the readMe on how to setup and use.
https://github.com/jakebullet70/X16FKEYMAPPER
#R47
Function Key re-mapper
- Jakebullet70
- x16FunctionKeyRemapper.zip
- (1.28 KiB) Downloaded 125 times
If you do not see any flak... Your not on target!
