Completed VERA Bin to BMX Convertor.
Stand Alone: No helper programs required.
At present only 8 bit files are supported.
Includes QB64PE Source code, Linux Executable, Windows .EXE
(also some sample files to convert).
If the .BIN file has a corresponding .PAL file that will be used as the Palette
(Must be 512 bytes in size). Otherwise VERA Default is used.
HERES THE PROGRAM
VERA BIN to BMX Convertor
Re: VERA BIN to BMX Convertor
going to steal a few ideas from this for my own conversion script (linked in the BMX topic)
