![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
NEW CODE HERE This still requires you to download the Google drive download below for the animation frame files. They are collectively to big to post on the forum. The zip is a bit over 100 mb's. The files you need from the below zip have an .A extension.
I will be posting a Youtube video of this running on hardware. I'm transcoding the video now.
Running on HARDWARE:
The video algorithm has been tested on HOSTFS, SD-Card Emulated & Hardware. On HOSTFS it's capable of about 22 fps.
On SD-Card - Emulated I'm a bit short of 10 fps. On Hardware it does better. 13.15 fps on one of my machines, 13.44 on the other.
FWIW The lower frame rate is on DEV0056 running r45. The Higher on PR0007 running r47.
It detects which file system it's on. On HOSTFS it Throttles to 13.2 fps deliberately to emulate hardware performance. It can't tell the difference between emulated SD-Card and HARDWARE SD-Card. On SD-Card it just goes as fast as possible.
File is to Big to include here due to multiple frame animation files. It's posted
on my Google Drive. https://drive.google.com/file/d/1fLBm7I ... sp=sharing
SPLASH SCREEN MENU SCREENS A COUPLE OF ANIMATION STILLS
HERE IT IS:
