ZCM/PCM-player without use of library
unartic
Post by unartic »
Here is a small demonstration on how to play ZCM files of any size, straight from disk. It uses a custom interrupt handler to keep the fifo-buffer filled. It consumes less then 256 bytes in total.
I included the theme of x16wars for demonstration.
Source
playzcm.asm
(3.85 KiB) Downloaded 247 times
Runnable demo
playzcm.zip
(427.91 KiB) Downloaded 194 times
5/14/2024: updated version in which the disk io is now outside the isr. Thanks to Tony3068 to point this out
Djehuti
Re: ZCM/PCM-player without use of library
Post by Djehuti »
I like your indentation style and I'm going to steal it. ;)
Very nice code. I've been working on something very similiar to this. I think I might just steal yours, ;) as I've got about 4 programming projects all going at the same time.
Good work...
