Mouse1
koyaa
Mouse1
Post by koyaa »
With R46 and a 65c02 the command MOUSE1 works after a CTRL-ALT-DEL reset.
With R47 (total ROM update - including SMC) and a 65816, the MOUSE1 command does not work after a CTRL-ALT-DEL.
The computer must be power cycled for the mouse to work.
As suggested, this was a hardware issue. I will have to get another Perixx mouse! Was using an unbranded Chinese optical mouse.
Re: Mouse1
Hi, I've tested this on my X16 with R47 (ROM, SMC, and VERA), and I'm unable to confirm this bug report.
Can you describe the exact sequence you're using to trigger this bug? Also, can you confirm the make and model of your mouse and keyboard?
This might be an SMC bug that's unique to your machine.
Re: Mouse1
I also tested this with Kernal R47 and SMC 47, all sorts of combinations of MOUSE1 + Ctrl+Alt+Del + Power Cycle. The mouse never failed.
Maybe you could show the output when you type HELP on the X16.
koyaa
Re: Mouse1
Post by koyaa »
TomXP411 wrote: Wed Apr 10, 2024 4:02 pm Hi, I've tested this on my X16 with R47 (ROM, SMC, and VERA), and I'm unable to confirm this bug report.
You are correct, this is a hardware specific issue. Changed mouse AND keyboard - no issue.
Re: Mouse1
Glad we could get this resolved! I'm going to move this over to the Tech Support area for future reference.
