waht ist error : gal ?
funkheld
Post by funkheld »
Hi good afternoon.
what is error: gal please?
Thanks.
greeting
I=40
POKE $9F37,I
START:
  GET A$
  B=ASC(A$)
  IF B=82 THEN GOSUB SCRLINKS
  IF B=84 THEN GOSUB SCRRECHTS
  SLEEP 1
GOTO START
SCRRECHTS:
  I=(I-1) AND 255
  IF I=0 THEN
    U=U-1
    POKE $9F38,U
    I=255
  END IF
  POKE $9F37,I
RETURN
SCRLINKS:
  I=(I+1) AND 255
  IF I=0 THEN
    U=U+1
    POKE $9F38,U
  END IF
  POKE $9F37,I
RETURN
Re: waht ist error : gal ?
you sneaky sneaky scrolled the error message outside of the visible screen I guess!
It's part of ILLEGAL QUANTITY ERROR.
hstubbs3
Post by hstubbs3 »
Man, I hate when I get GAL QUANTITY ERRORs .... There's just never the right amount of femininity when you need it most.
?ILLEGAL
Each letter is 8 pixels wide..
You scrolled ? I L L E => 5x8 = 40 pixels and then got the error..
I tried just copy/paste that code into the online emulator and got illegal quantity error for POKE $9F38,U
The bit of code provded never sets a value for U ?
I=40 is at the start ..
but how can I U=U-1 or POKE $9F38,U if U isn't set???
If that doesn't help please fill in more details about the code in question.
hstubbs3 wrote: Tue Mar 26, 2024 10:49 pm Man, I hate when I get GAL QUANTITY ERRORs .... There's just never the right amount of femininity when you need it most.
GAL can also stand for "Get A Life", which I'm sure some people may tell me after I talk about the retro computer movement and the CX16. :D
Or it could also stand for Generic Array Logic - https://en.wikipedia.org/wiki/Generic_Array_Logic
That being said, given the butterfly is chopped in half in the original screen capture, dessertfish has provided the correct answer.
hstubbs3
Post by hstubbs3 »
Edmond D wrote: Tue Mar 26, 2024 11:18 pm
Indeed, I was actually more concerned with which line of the code was giving the error..
I'm still an impulsive nerd so of course I has to make some attempt at humor in the process.
Funkheld, U=U-1 ...
is U allowed to go negative and still be POKEd into some location in memory?
You may need to instead have U count UP to 256 and then POKE $9F38,256-U
or... actually, the scroll registers wrap at 1024, which is larger than 1 BYTE ... to make negative would be something like
POKE $9F38,U+256
POKE $9F39,$FF
can only POKE 0-255 ... fractional and negative POKEs are not allowed. Imaginary or Complex POKEs are strictly prohibited.
DAng it I think I already made a Holy Hand Grenade reference this week...
BASIC will not raise an error on the following.
POKE $400, 3.9
However what is happening is it's just discarding everything after the Decimal. So the above is the same as POKE $400, 3
It is forbidden to POKE a negative number into any address; POKE is only valid for unsigned values that fit into a single byte. Your U=U-1 statement reaches a value of 0 and then goes below it, and this causes the error. You should have bounds checking in your code to prevent this, such as:
U = U - 1 : IF U < 0 THEN U = 0
funkheld
Post by funkheld »
You can scroll the screen the textmode : 128 bytes right and left and 60 bytes up and down.
1 ascii has 2 bytes
Here you can scroll infinitely to the right and left.
U will not be minus because U is a byte in prog8 .
the program with prog8 works.
That's why my question was with byte, which changes the value at 255.
greeting
%import graphics
%import math
%import textio
%import palette
%import syslib
%import diskio
main {
        ubyte background_color
	ubyte radius
	ubyte color
	ubyte z
	ubyte u
	ubyte x
	ubyte y
    sub start() {
	   cx16.screen_mode(128, false)
           graphics.enable_bitmap_mode()
	   void diskio.vload_raw("funkpal.pal", 1, $fa00 )
            void diskio.vload_raw("test.raw", 0, 0)
	    draw_circles()
	    txt.plot(6,10)
	    txt.print("schiebe screen")
	    z=40
	    poke($9F37,z)
    waitkey:
	  sys.waitvsync()
	  ubyte key=cbm.GETIN()
          keypress(key)
	  goto waitkey
	sub keypress(ubyte key) {
        when key {
		  'r' -> sl()
		  't' -> sr()
    sub draw_circles() {
          x=100
	  y=100
	  radius=30
      color = 7
      graphics.colors(color, 0)
      graphics.disc(x, y , radius)
      x=200
      y=100
      radius=30
      color = 189
	sub sr() {
	   z=z-1
	   if z==0 {
	     u=u-1
             poke($9F38,u)
	     z=255
	  poke($9F37,z)
	sub sl() {
	    z=z+1
	    if z==0 {
	      u=u+1
              poke($9F38,u)
            poke($9F37,z)
funkheld
Post by funkheld »
U does not need to be set in basic, it is 0
bas basic program is ready above.
Thanks.
greeting
hstubbs3
Post by hstubbs3 »
funkheld wrote: Wed Mar 27, 2024 7:46 am ------------------------------------
Thanks.
greeting
Then your basic code is trying to POKE $9F39, -1
and can't poke negative...
In prog8 it would almost work.. -1 represented in a BYTE would be $FF => 255 ...
scrolling horizontally to 255 would not be same as -1 unless the screen width was 256 though..
for 320x240 screen.. say..
say the tile map is 64 tiles wide - 512 pixels..
The loop could be something like this -
U = U-1
IF U<0 :
U=512-1
IF U>255:
POKE $9F38,U-256
POKE $9F39,1
ELSE:
POKE $9F38,U
POKE $9F39,0
