error with basl .
funkheld
error with basl .
Post by funkheld »
Hi good afternoon.
what kind of error is this in the Basl program?
Thanks.
greeting
RESTORE ASM
READ Z
FOR P = 1024 TO (1024 + Z)
  READ Z
  POKE 1024+P,Z
NEXT P
ASM:
 DATA 73
 DATA  $A9, $04, $85, $01, $A9, $44, $A0, $20, $20, $63
 DATA  $FE, $A9, $3A, $A0, $20, $20, $24, $FE, $A9, $3F
 DATA  $A0, $20, $20, $5A, $FE, $20, $21, $FE, $A9, $3F
 DATA  $A0, $20, $20, $5A, $FE, $20, $21, $FE, $20, $06
 DATA  $FE, $85, $02, $84, $03, $A0, $00, $B1, $02, $F0
 DATA  $06, $20, $D2, $FF, $C8, $D0, $F6, $60, $84, $1C
 DATA  $F5, $C2, $8F, $83, $20, $00, $00, $00, $82, $00
 DATA  $00, $00, $00,
 END
Re: error with basl .
To see the actual problem line, you need to
LIST 3
Remember that BASLOAD just adds line numbers and converts labels and variables. So you need to look at the converted source to see what the reported error is.
But there are several things wrong here.
First, you are setting up the loop conditions with Z, then changing Z inside the loop.
This is a bad idea.
Also, you appear to be loading your DATA into at 1024 (based on the initial value of P), but then you're adding 1024 inside the loop. This will actually load the data into address 2048 - which is where the BASIC program resides. So you've just succeeded in overwriting the program with garbage data.
Try this loop, instead:
READ Z
A1=1024
A2=A1+Z-1
FOR P=A1 TO A2
  READ Z
  POKE P,Z
NEXT
funkheld
Post by funkheld »
Hi, Thank You.
I misinterpreted that completely. :oops: :oops:
Thanks.
greeting
