Hi good afternoon.
the string:
str name = "test.bmx"
is not recognized for:
bmx.open(8, name)
thanks
greeting.
%import textio
%import palette
%import bmx
%option no_sysinit
%zeropage basicsafe
main {
sub start() {
void txt.waitkey()
load_bmx()
sub load_bmx() {
bmx.open(8, name)
prog8 : str name = "test.bmx"....bmx.open(8, name)
Re: prog8 : str name = "test.bmx"....bmx.open(8, name)
Sure, because "name" is not in scope in the load_bmx subroutine. It's defined in the start subroutine.
hello thanks for help.
I now make png images with this converter
to get finished:
X16PngConverter.exe
effective and fast.
that's how I imagined it.
Load images quickly and easily.
wonderful.
greeting
to get finished:
X16PngConverter.exe
effective and fast.
wonderful.
%import textio
%import palette
%import bmx
%option no_sysinit
%zeropage basicsafe
main {
sub start() {
bmx.open(8, name)
load_bmx()
txt.color(5)
txt.plot(6,4)
txt.print("pebisoft")
repeat {}
sub load_bmx() {
bmx.palette_buffer_ptr = memory("palette", 512, 0)
sys.memset(bmx.palette_buffer_ptr, 512, 0)
palette.set_rgb(bmx.palette_buffer_ptr, 256)
void cx16.screen_mode($80, false)
cx16.VERA_L0_CONFIG = cx16.VERA_L0_CONFIG & %11111100 | bmx.vera_colordepth
cx16.GRAPH_set_colors(0, 0, bmx.border)
cx16.GRAPH_clear()
uword offset = (320-bmx.width)/2 + (240-bmx.height)/2*320
if bmx.continue_load_stamp(0, offset, 320) {
activate_palette()
sub activate_palette() {
cx16.VERA_DC_BORDER = bmx.border
cx16.r1 = bmx.palette_buffer_ptr
cx16.r2L = bmx.palette_start
cx16.r3L = lsb(bmx.palette_entries)
do {
palette.set_color(cx16.r2L, peekw(cx16.r1))
cx16.r1+=2
cx16.r2L++
cx16.r3L--
} until cx16.r3L==0
- bmx-bild.jpg (21.78 KiB) Viewed 441 times
