Hi good afternoon.
I have a lot of questions, please, because at 75 years old I don't know much English.
I come from Germany.
I can do the listing with DOS"$".
My programs are in the “BASIC” DIR folder.
Which command can I use to open the folder to load my programs with LOAD"TEST.PRG",8 from the "BASIC" folder?
Thanks.
greeting
My programs are in the “BASIC” DIR folder. how to open the folder "BASIC"
- dir.jpg (26.3 KiB) Viewed 708 times
Re: My programs are in the “BASIC” DIR folder. how to open the folder "BASIC"
You can either use
DOS"CD:BASIC"or
@CD:BASIC
Hello, thanks for help.
you are very helpful here.
Thanks.
greeting
Thanks.
greeting
