ASM with acme.exe compiliert. how to start please.
funkheld
Post by funkheld »
Hi good afternoon.
I have this ASM program from x16-programmers.
a prg is created with acme.exe.
How do you set the start address in the asm ?
load"float.prg",8 >>>>> is ok
how do you start prg?
Thanks.
!to "float.prg", cbm
*=....????  How do you set the start address for the prg?
CHROUT = $ffd2
FOUT   = $fe06
FMULTT = $fe21
FDIV   = $fe24
CONUPK = $fe5a
MOVFM  = $fe63
 lda  #4
 sta  $01
 lda  #<flt_two
 ldy  #>flt_two
 jsr  MOVFM
 lda  #<flt_g
 ldy  #>flt_g
 jsr  FDIV
 lda  #<flt_time
 ldy  #>flt_time
 jsr  CONUPK
 jsr  FMULTT
 lda  #<flt_time
 ldy  #>flt_time
 jsr  CONUPK
 jsr  FMULTT
 jsr  FOUT
 ; rom bank 4 (BASIC) contains the fp routines.
 ; FACC= g/2
 ; ARG = time
 ; FACC = g/2 * time
 ; again ARG = time
 ; FACC = g/2 * time * time
 ; to string
 ; print string in AY
 sta  $02
 sty  $03
 ldy  #0
loop:
 lda  ($02),y
 beq  done
 jsr  CHROUT
 iny
 bne  loop
done:
 rts
flt_g:      !byte  $84, $1c, $f5, $c2, $8f  ; float 9.81
flt_time:   !byte  $83, $20, $00, $00, $00  ; float 5.0
flt_two:    !byte  $82, $00, $00, $00, $00  ; float 2.0
Re: ASM with acme.exe compiliert. how to start please.
I don't know the ACME assembler dialect, but usually to set the start address you do
* = $2000
or perhaps:
.org $2000
Depending on what the assembler produces, you can then load that in Basic like so:
LOAD "FLOAT.PRG",8,1
and start it with
SYS $2000
The ",1" parameter for the LOAD command is to tell Basic to load the program not as a basic program but as a machine code program at the address it is assembled to.
There are also ways to create a "normal" basic program that you can simply LOAD and then RUN, but that requires a so called "basic stub" at the start of the program which need to start at $0801 in this case. There are many ways to do this and I don't know what would be Acme's way - maybe someone else knows this detail.
The Commander X16 starts is BASIC space at $801, so if your program has the usual 0 SYS 2064 BASIC stub, then you'd want to use * = $0801.
Otherwise, for small routines (less than 1 KB) I'd suggest using the Golden RAM at $400. The block at $400-$7FF is reserved for machine language routines.
funkheld
Post by funkheld »
Hello thanks .
thank you for your help.
wonderful , is ok.
greeting
