Hello,
I have been playing with the X16 Emulator on the Mac.
I have downloaded the X16-Demo files from GitHub.
How do I use the .BAS files in the basic folder?
I can open them in the editor to see the basic program complete with line numbers.
I just down know how to load the basic file contained in the text file.
Thanks.
Colin
Beginner Questions about the X16-Demo stuff.
Re: Beginner Questions about the X16-Demo stuff.
There is a way to do it. Read to the end.
Commodore BASIC isn't designed to open ASCII BASIC files. When you type BASIC commands it converts them to single byte Tokens internally and when you SAVE "MYFILE.PRG" it saves those tokens.
With the Emulator you can fool it into thinking you just type really fast. Open the .BAS file in a text editor, copy all of it to the clipboard.
Then Paste it to the emulator window, (In Windows or Linux Ctrl/V, I'm sure there's an equivalent on Mac).
Once the scrolling is done. Type RUN and ENTER to see what you've got.
Occasionally on Windows when I do this a line or two might get corrupted. If it doesn't work the first time try at least twice before you think the program your loading has any bugs.
There is actually a simpler way to do it, but basically it works in the same way as already described. You can load a BASIC text file directly into the emulator by using the option -bas. For example x16emu -bas file.bas -run will load the file and run it immediately.
There's a third way to do it, and this will work even from an actual machine: The EXEC command.
You have to load the text of the program into memory (usually high memory is a good choice for this, pick any bank other than 0. Generally bank 1 and address $A000 is a good place to start.)
Use BLOAD to do it. The first line here is what you type in (adjusted, of course to change "WHATEVER.BAS" to the actual name of the file you're trying to load. The lines after that are what the computer will say back to you, as it's loading the file. The hexadecimal numbers following the 'TO' in the output will vary according to the length of the file you're loading.
It will literally type it out on the screen for you just the same as if you'd pasted it as ahenry3068 describes.
Yes, this is BY FAR the most complicated way to go about it so far mentioned; it's also the only way to do it on the actual hardware, short of loading the program into the editor and, after carefully changing all the GOTO and GOSUB targets to labels and placing the labels in the right places in the code, deleting the line numbers, and then running BASLOAD. That's even more complicated, I think.
BLOAD"WHATEVER.BAS",8,1,$A000 SEARCHING FOR WHATEVER.BAS LOADING FROM $01:A000 TO $01:A123 READY.Then you type:
EXEC $A000,1to load from address $A000 in bank 1.
I will add this note. In most cases the .BAS files are included for reference if you want to study and/or change the code.
There should almost always be a corresponding .PRG for the .BAS file that can just be loaded with LOAD.
