I present to everyone who cares to listen:
The first finished on-system compiler of the X16 - A Brainf*** compiler
It still uses ASCII, mostly ISO mode, but also uses 0A as newline instead of 0D. Also, input is terminated by 00, memory cells are limited to one byte, and there's only 256 of them. So have fun y'all!
XBrained: A Brainf*** Compiler
Re: Brainf*** Compiler
I knew it would happen eventually.
Hi, guys. I know the name of the programming language is acceptable in some circles... but the forum is both SFW and PG.
For anyone who is not familiar with the BrainF* programming langauage: it's designed to be the smallest possible language, while also being "complete".
You can read more at Wikipedia: https://en.wikipedia.org/wiki/Brainf***
