Hi!
I need the output of LOAD"$=T" from a directory with a few files and sub directoties in where the date and time format is English (USA).
Unfortunatly I can't get the emulator on my Windows pc to output it, after changing the windows regional settings.
So if someone can do this for me:
LOAD"$=T"
SAVE"LST-ENG.BAS"
and post the file back, it would be greatly appreciated
LOAD"$=T"
Re: LOAD"$=T"
Here you go.
But I'm curious, as to why the emulator would fail on your machine to do this? Do you get an error or does it crash?
- LST-ENG.BAS
- (6.25 KiB) Downloaded 281 times
Re: LOAD"$=T"
Thanks!
No problems with the emulator As I live in the Netherlands the default notation is dd-mm-yyyy HH:mm:ss. After changing regional settings to English USA on Windows I see the mm/dd/yyyy notation everywhere (even in a command line dir command), but within the emulator it keeps the Dutch notation. Strange enough the same happens with Dosbox for some reason.
So I just needed the listing to test my program
Re: LOAD"$=T"
Ok, this is unexpected. The contents of your .BAS file also has 24-hour time notation.
Does this mean it is the default for Commander x16?
Re: LOAD"$=T"
ISO8601 date format for the win!
Re: LOAD"$=T"
I'm also from the Netherlands (STROOPWAFEL!) and my locale (on Linux) is set like so
$ date do 16 nov 2023 18:51:59 CET $ echo $LC_TIME nl_NL.UTF-8
but I would hope the regional settings is of no consequence to the format of the date/time returned in the emulator directory listing. If it is, I consider that a bug in the emulator
