IBM MODE 13H PALETTE CLONE
I cloned a very reasonable approximation of the IBM VGA Mode 13h default palette on VERA. I thought it could be useful for anyone porting code from that platform.
Archive contains DPAL.BIN -- 512 byte VERA Palette Image (default VERA Colors) MODE13H.PAL -- 512 byte VERA Palette Image (Mode 13h clone) VGAPALETTE -- Comma Delimited Text file I used to help create the VGA Palette. FORMAT Is Pal_Entry,R,G,B where R,G & B are real numbers between 0-100 and are calculated as a percentage of R,G,B Pixel Value. I got these numbers by Loading the VGA Palette Graphic from Wikipedia and Eye Droppering it in GIMP. (If you examine this file you will see entries 16-31 don't exist, VGA & VERA both use this for Gray Scale so no change is needed) VGAPAL.PRG -- The BASIC program that creates MODE13H.PAL (Tokenized) VGAPAL.BAS -- The BASIC Source for VGAPAL.PRG (BASLOAD Syntax)
THE CODE AND PALETTE ARCHIVE
VGAPAL.zip
(6.9 KiB) Downloaded 257 times
The VGA Mode 13h Palette from Wikipedia
The VGA Clone Palette on the X16 Emulator.
