Hi!
Being a highlevel programmer for several decades (started in the dos-ara) I'm now commited to learn assembly and x16 seems to be a great platform to do it on.
I'm using ca65.
I'm trying some 'random' basic stuff to get a feeling.
With SETLFS, SETNAM and LOAD using "$" as the filename, I'm able to load the filelist of the current directory.
Now I want to change the directory to a subdirectory and load a filelist from that directory. After some extensive googling, I'm not able to find it, so I hope somone can help me out here
Change directory - assembler
Re: Change directory - assembler
https://github.com/X16Community/x16-doc ... nd-channel
use the command channel (15) to send the command "CD:<directory>"
Thanks! That was the missing link.
I now have this, but it doesn't work. Can you point me in the right direction?:
.org $080D .segment "ONCE" LOAD = $FFD5 CLOSE = $FFC3 SETLFS = $FFBA SETNAM = $FFBD jmp start DOS_COMMAND: .byte "CD://DIR1/DIR2" END_DOS_COMMAND: tbuffer: .res 20000, $41 start: lda #2 ; Logical Number ldx #8 ; device ldy #15 ; control channel jsr SETLFS lda #(END_DOS_COMMAND-DOS_COMMAND) ; command length ldx #<DOS_COMMAND ldy #>DOS_COMMAND jsr SETNAM lda #0 ; load ldx #<tbuffer ;don't know why this is needed for the command channel ldy #>tbuffer jsr LOAD lda #2 jsr CLOSE rts
I think you must use Kernal function OPEN, not LOAD.
The command gets executed, and then you may read the drive response from the opened file sequentially.
This is done by first setting the file as input with CHKIN and then read one char/byte at a time with CHRIN.
You need to clean up this when done with CLRCHN and CLOSE.
