x16emu debug driver kernal wedge
Took a crack at writing a device driver for x16emu's debug channels. This installs the driver as device #6; if you open it with secondary address 0, everything sent to the channel comes out through the debug text port at $9fbb. If you open it with SA 1 or 2, every byte sent to the channel instead comes out through the corresponding debug port.
debug_driver.asm
- (7.18 KiB) Downloaded 303 times
debug_driver.prg
- (647 Bytes) Downloaded 359 times
