Hi
I'm sure this is just a 'me' thing but searches aren't helping and I don't seem to find what I'm looking for in the BASIC Prog. Ref Guide on GITHUB.
What are the commands that BASIC supports in 'immediate' mode, i.e. when it is NOT running BASIC program? I believe we have some new additions - OLD for un-NEWing a program, REN for renumber.
Are there others, if so, what are they and where can I find documentation on them?
Thanks in advance!
Immediate mode (i.e. not in a program) BASIC commands
Re: Immediate mode (i.e. not in a program) BASIC commands
ALL BASIC commands can be run from inside or from outside the context of a program. Also, anything that can be typed at the READY prompt can be executed as a line in a BASIC program. AFAIK, there aren't any that are limited to one or the other.
(EDIT: This is incorrect -- there are three which are limited to running inside or outside a program, see later posts)
All of the supported BASIC commands on the X16 can be found here in the documentation. There are several commands in the docs that are listed but not explained, those are all taken directly from C64 BASIC and explanations can be found here.
Got it - thanks very much for that clarification. I think what confused me for a while is I thought I'd seen somewhere there were search and/or replace commands made available in the editor. I guess that was wishful thinking mixed in with seeing some code for these functions in an old C64 magazine a lifetime or 3 ago!!DragWx wrote: ↑Tue Jun 27, 2023 1:29 am ALL BASIC commands can be run from inside or from outside the context of a program. Also, anything that can be typed at the READY prompt can be executed as a line in a BASIC program. AFAIK, there aren't any that are limited to one or the other.
There are some typical editor commands that can't be used inside a program e.g. REN, and there are some typical program commands that can't be used outside a program e.g. INPUT.
Example session using x16emu R43 (I changed the color of the user input to yellow):
READY. 10 REN RUN ?ILLEGAL DIRECT ERROR IN 10 READY. INPUT Y ?ILLEGAL DIRECT ERROR READY.I believe one could change the implementation so that all commands could work both bare in the editor and in a program, but it might be a lot of work. ZX Spectrum BASIC can have INPUT in immediate mode. E.g. in ZX Spectrum+ you can run this outside a program:
for i=1 to 3:input a:print a+a:next i
Wow, you're right! I didn't know that.
After looking through the ROM, it looks like there's only three that throw a "direct" error: INPUT/INPUT#, GET/GET#, and REN.
Fun fact: The way BASIC checks if you're running a command in direct mode or not is by checking the high byte of the current program line number to see if it's $FF. Normally, that would encompass line numbers 65280..65535, but BASIC avoids any problems by not allowing you to use line numbers higher than 63999.
Thanks all - useful stuff there - good to know ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
