10PrintRacerX16
JanBlomqvist
10PrintRacerX16
Post by JanBlomqvist »
A conversion of the 8 Bit Show and Tell Basic game from 40 column PET to 80 column X16.
Use 4 and 6 keys for Left and Right
This game can be good as a start to use the VPOKE and VPEEK commands in text mode Basic.
/Jaix Bly
Bug fix according to MarkTheStrange @ The x16 Discord server.
https://discord.com/channels/547559626024157184/629903630916648962/1052617335149695007
The screen addresses uses to bytes, not one as I assumed, Thanks Mark for showing this!
Now also only one keypress is needed to move the "car" now it works as good as the pet, c64 and mega65 versions.
10PrintRacerX16
10PrintRacerX16
10PRINTRACEX16.PRG
10PrintRacerX16
(634 Bytes) Downloaded 274 times
