KERNAL Test
KERNAL Test
This is a small, proof-of-concept C program which tests KERNAL functions on the X16.
Routines currently tested:
  • chrout
  • memtop, both read and write
  • membot, both read and write
  • setnam
  • setlfs
  • load to RAM
  • load to VERA (well, sort of)
  • set time and read time
It uses CC65's library to set registers and invoke routines.
The source code is here: https://github.com/bobbyjim/x16-kernal-test
Added SETTIM and RDTIM
KERNAL Test
KERNAL Test
Screen Shot 2021-10-19 at 10.24.06 PM.png (19.37 KiB) Viewed 420 times
[The extension est has been deactivated and can no longer be displayed.]
TEST1.BIN
KERNAL Test
(258 Bytes) Downloaded 96 times
PETFONT.BIN
KERNAL Test
(2 KiB) Downloaded 94 times
