Read Directory in BASIC
This reads the disk directory in BASIC. This is a super simple example and doesn't actually parse the files... it's just smart enough to read "$" and print it to the screen.
This version is smarter. The directory is actually read as a BASIC file. Each line has a 2 byte link address, 2 byte line number, a variable length text string, and a null.
So this program reads and discards the link address, reads a 16-bit number for the file size, then reads until the null to get the filename and filetype.
DIR.PRG
(968 Bytes) Downloaded 356 times
