Tiled Map Editor BASIC DATA export
Justin Baldock
Post by Justin Baldock »
This file is a JavaScript extension for the Tiled Map Editor. It will export your Tiled map as BASIC DATA statements. Inspired by Johan Kårlin export files.
When exporting it will prompt for the starting BASIC line number. The script will output a few data statements about the map. Then the tile data will be output in DATA statements with 16 elements.
Updated so it creates data in the TILE_BASE data expected of VERA.
tiled-basic-map-extension.js
[The extension .js has been deactivated and can no longer be displayed.]
