Design goals:
- Use plain text files
- Store text buffer in banked RAM (512KB to 2 MB)
- Handle large text buffers efficiently
- Simple modeless user interface inspired by GNU Nano
- Implement basic editing functions well - refrain from making the program too feature-rich
- Support both ISO and PETSCII modes
The standard version of the editor consists of just one file, and it's loaded and run in the same way as a BASIC program. Use the following command to start the program in the emulator:
- x16emu -sdcard sdcard.img -prg X16EDIT-x.x.x.PRG -run, where x.x.x is the program version.
- X16EDIT-HI-x.x.x.PRG, a version of the editor to be loaded and run from memory address $6000
- x16edit-rom-x.x.x.bin, a ROM based version of the editor
The program files, the manual and the source code are currently only available at https://github.com/stefan-b-jakobsson/x16-edit
Released under GNU General Public License v 3 or later.
