MineX16
Elektron72
MineX16
Post by Elektron72 »
This is a minesweeper clone for the Commander X16. It allows custom minefield sizes up to 38x24, with almost any amount of mines.
To start, load and run MINEX16.PRG.
Controls:
  • Main Game
    • Left click to reveal a tile
    • Right click to flag a tile
    • Click on the face to reset
    • Press space to open the configuration screen (will reset the minefield)
    • To exit, reset the machine (Ctrl-R on the emulator)
  • Configuration
    • Space to open and close
    • Use the + and - buttons next to each digit to change the width, height, and number of mines
    • Numbers are capped to a specific range; attempting to select an invalid value will set the number to its maximum or minimum value
    • Click any of the presets to set all of the numbers at once
Note: The game uses kernal functions to handle the mouse, so any weirdness is most likely caused by the emulator.
  • Fixed issues with left+right click.
MineX16
MineX16
MINEX16.PRG
MineX16
(12.75 KiB) Downloaded 98 times
