YM2151 SYNTH UI
Miklós Pathy
YM2151 SYNTH UI
Post by Miklós Pathy »
synthuiym2151.prgA simple user interface for the YM2151 synth.
Usage:
LOAD "YM2151SYNTHUI.PRG",8,1
SYS$1000
Use the keys as any tracker to play.
Use the sliders an buttons with the mouse to adjust synth params.
Hold key : in this mode the last note is hold until spacebar is pressed.
Transpose is a slider now
Global settings (all channel) sliders are grey now.
LFRQ and AMDPMD sliders are longer for more precise settings.
Pressing enter dumps the YM2151 registers to the screen.
synthui.prg
YM2151 SYNTH UI
YM2151 SYNTH UI
synthui.prg
YM2151 SYNTH UI
(19.52 KiB) Downloaded 101 times
synthui.prg
YM2151 SYNTH UI
(19.27 KiB) Downloaded 99 times
YM2151 SYNTH UI
YM2151 SYNTH UI
