Argis Paint
Zen1th
Argis Paint
Post by Zen1th »
"Argis" is a very simple paint program. I i made it mostly to test programming with the VERA chip and it is currently not very well optimized. It supports brush and fill tools and 16 colors from the C64 palette.
Instructions:
The first button is to select brush tool and the second is to select fill tool.
Click on the color on the down right to select a new foreground color.
  • Brush now can fill gaps between cursor moves
  • Fixed a few bugs
Argis Paint
Argis Paint
ARGIS.PRG
Argis Paint
(7.49 KiB) Downloaded 106 times
