Ziggurat
theelkmechanic
Ziggurat
Post by theelkmechanic »
Ziggurat is a Z-machine interpreter written from scratch to take advantage of the power of the Commander X-16. Relive the nostalgia of playing your old Infocom adventures or new Inform stories.
(Note: This is a pre-alpha release. Almost nothing works correctly yet. Please be patient. Development is on GitHub if you want to help out!)
Version 0.0.9 is updated for the r39 emulator/ROM release and Proto 2 hardware. Many thanks to Elektron72 for headerless loads, and to mist64 and ZeroByteOrg for fixing loads into banked RAM; game file loading time is much improved.
Ziggurat
Ziggurat
Ziggurat
Ziggurat
Ziggurat
Ziggurat
x16-ziggurat-0.0.9.zip
Ziggurat
(68.83 KiB) Downloaded 128 times
x16-ziggurat-0.0.8.zip
Ziggurat
(68.9 KiB) Downloaded 161 times
x16-ziggurat-0.0.5.zip
Ziggurat
(67.84 KiB) Downloaded 144 times
