Crossplatform Tools List
Deflemask Music Tracker (in Sega Arcade mode: YM2151+SEGA PCM)
https://deflemask.com/
- maybe we can have YM2151+VERA PCM Deflemask Module player on X16
SAA1099 Tracker
https://saa1099tracker.borik.net/
https://github.com/mborik/SAA1099Tracker/find/master
- Maybe we can have SAA1099 player on X16
Lanex LNX SAA1099 Tracker
https://www.ilnx.cz/lnxtracker/install/
TILEStudio (background, sprites, maps)
http://tilestudio.sourceforge.net/
TILEStudio2
https://www.wieringsoftware.com/ts2/
- maybe we can use TS (Basic, ASM)
TilED MapEditor (map maker)
https://www.mapeditor.org/
Also here is how to load TilED map into BASIC:
https://www.commanderx16.com/forum/index.php?/files/file/75-tiled-map-editor-basic-data-export/
- maybe we can use maps in txt format
If You know other Crossplatform tools let me know!
https://cc65.github.io/ - cc65 C/Assembly toolchain for 6502 family cross-development, including support for the Commander X16
Am I allowed to self promote?
https://prog8.readthedocs.io/ cross-compiler for in-development "Prog8" language targeting 6502 machines C64 and CommanderX16
