New graphics upload: Petscii Editor
ScragglyHermit
Post by ScragglyHermit »
Petscii Editor
View File
A very simple petscii graphic editor for the x-16. With only a few functions:
  • enter a single char
  • draw a line
  • draw a rectangle
  • copy a region
  • save a drawing
  • load a drawing
HELP.PSK - example file and also help
Binary File format  (.PSK):
  • a few bytes for the header (will change)
  • 2 bytes for width (currently only 80)
  • 2 bytes for height (currently only 60)
  • data array of interleaved character code (1 byte) and color (1 byte). Almost the same as Vera except Vera pads width to 256 columns (not 80).
