BASIC SCREEN $80 and PSET, RECT, etc
Iegen
Post by Iegen »
Does PSET, and RECT work in SCREEN $80 in the R41 emulator?
The documentation says there are two layers on SCREEN $80, one graphic and one text.  When I do RECT 100,100,200,200,2 ... nothing happens on the screen in immediate mode.  Am I doing something wrong?
Thank you
Ender
Post by Ender »
Not sure what you're doing wrong. That same command seems to work fine for me.
Iegen
Post by Iegen »
It's working now for me also.  Not sure what I was doing to make it not work.
Perhaps a previous command set the system "off."  As a software QA I've seen problems where the system goes into the weeds but doesn't indicate a problem whatsoever until a "future" trigger exhibits a problem that it normally wouldn't.
Windows users might be familiar with the "Reboot and Retry" troubleshooting method of solving a problem.
Or the Roy-Moss method, aka "Have you tried turning it off and turning it back on again?"
Back in the NT days support would say re-install the OS which gave the programmers a day or so to figure out what a real solution to the reported issue would be. The 8 bit days didn't have that stall tactic; perhaps in part because direct customer support didn't exist.
