Neat one-liners
grml
Neat one-liners
Post by grml »
POKE34,203:POKE35,96:FORI=0TO128:POKE$9F2A,I:POKE$9F2B,I:SYS34:NEXT
Works best right after reset while the X16 logo is still visible.
This part:
POKE34,203:POKE35,96:SYS34
does wait for vblank irq, for the rare case when you need it in BASIC. The address is arbitrary, it will work anywhere in RAM.
Add your own interesting one-liners or short BASIC programs below if you must. Inb4 the inevitable "maze" generator
grml
Re: Neat one-liners
Post by grml »
Sierpiński triangle:
CLS:FORY=0TO59:FORX=0TO79:VPOKE1,$B000+Y*256+X*2,78-((XANDY)>0):NEXT:NEXT
It looks better if you squint a little :lol:
And damn, BASIC is still slow as hell even at 8 MHz.
Re: Neat one-liners
I love the sierpinsky oneliner!
Jestin
Re: Neat one-liners
Post by Jestin »
I tried putting these together, and they make a great two-liner! Zooming Seirpinski!
grml
Re: Neat one-liners
Post by grml »
COLOR13,0:CLS:FORT=0TO9^9:?CHR$(164+2*RND(0)+INT(2*RND(0))*41);:NEXT
This one is interesting. If you watch it go for a minute, you can see the pattern go through a bunch of distinctive phases while the RNG "warms up", until it finally seems to generate more uniformly distributed numbers.
First it's lots of diagonals and vertical lines, then lots of horizontal lines for a while
then mostly diagonals but clearly biased towards one direction,
and only then the actual intended pattern emerges after about ~4 screens.
Re: Neat one-liners
That is unexpected and slightly worrying behavior of the rng...
When running the same oneliner on the C64 (in vice) there is no such 'phasing', it seems uniform right from the start....
(the same when running an equivalent program written in prog8)
Yeah, you should probably be using RND(1) instead of RND(0) in the BASIC oneliner, that seems to fix the lack of uniformedness on the X16.
Re: Neat one-liners
Is it allowed to cheat a tiny little bit by setting up a variable first?
If so, this is my entry:
first set up the variable:
M$=CHR$(145)+CHR$(17)+CHR$(157)+CHR$(29)
and then the one liner itself:
CLS:LOc30,40:FoI=0TO9^9:COlRn(1)*16:?Ch(209)Ch(157)Mi(M$,1+Rn(1)*4,1);:Ne
(yes, it uses token abbreviatons to fit it under 80 characters. They look a bit weird in ascii due to the case flip, if you paste the line in the emulator it does work correctly)
EDIT: it can be done on 1 line and so it adheres to the rules again, but it requires you to embed the actual characters into the line instead of using ascii-copyable chr$ notation:
1 = shift-Q , a ball
2 = cursor left
3 = cursor up
4 = cursor down
5 = cursor left
6 = cursor right
grml
Re: Neat one-liners
Post by grml »
desertfish wrote: Sat Jan 21, 2023 10:32 am Yeah, you should probably be using RND(1) instead of RND(0)
Yes, that's it. At least I got this beautiful oneliner artwork out of my blunder:
SCREEN128:S=16:FORY=0TO239:FORX=0TO319:PSETX,Y,S+S*RND(0):NEXT:NEXT
desertfish wrote: Sat Jan 21, 2023 11:54 am Is it allowed to cheat a tiny little bit by setting up a variable first?
Comparing twoliners against oneliners seems a bit unfair to me. :) It's too bad you have to use CHR$. It would fit on one line if you could copy those chars verbatim, and remove the CLS.
Thanks for showing me how to copy abbreviated tokens.
SCr128:FORY=0TO239:FORX=0TO319:PsX,Y,136-119*SIN((X+2*Y)/(X+Y+59))+Rn(1):Ne:Ne
This one I call STRIPES OF PATIENCE. A picture would only deprive you of a quintessential and beautiful real-time art experience.
Re: Neat one-liners
I made it into a one liner but you can no longer copy paste it from the forum because of the embedded control characters that you have to type now ;)
Re: Neat one-liners
desertfish wrote: Sat Jan 21, 2023 10:32 am ... Yeah, you should probably be using RND(1) instead of RND(0) in the BASIC oneliner, that seems to fix the lack of uniformedness on the X16.
Does anything interesting happen with RND(T) in one of the RND() functions ... that is, using a different seed each time through the loop?
