is assembly language and monitor covered in the x16 manual?
I wanted to ask : is assembly language and monitor covered in the x16 manual?
We are planning a separate guide for that, but for now just click Downloads above to be taken to the current documentation.
No. Assembly language is something you need to learn from other sources - like Jim Butterfields book for the C64 still one of the best books to read.
Here are some links (depending on the language you speak/read)
German:
https://www.retro-programming.de/programming/assembler/
English:
https://skilldrick.github.io/easy6502/
Here is Jim Butterfields book...
http://www.1000bit.it/support/manuali/commodore/c64/ML_for_the_C64_and_Other_Commodore_Computers.pdf
Also a good thing to understand the C64 book. It is actually everything that is referenced from the X16 dokumentation (e.g. BASIC, KERNAL calls etc.)
http://www.zimmers.net/anonftp/pub/cbm/c64/manuals/C64_Programmers_Reference_Guide.pdf
And this documentation to understand all the different inner workings of the Commodores ... very extensive and also quick reference.
https://archive.org/details/Complete_Commodore_Inner_Space_Anthology_The_1985-03_Transactor_Publishing
The Monitor is covered in this document:
https://github.com/commanderx16/x16-docs/blob/master/Commander X16 Programmer's Reference Guide.md#machine-language-monitor
Thanks for that! While I wrote a lot of 6502 "back in the day," my work was almost exclusively on the Apple ][ series. As such, the books I have are all centered around those systems. Having a good C64 reference will help with some things I want to fiddle with for the Commander X16!
Will there be appendices listing tables of things like the Vera registers, or special memory locations as a quick reference?
There is a reference chart in the works for that kind of thing yes. More info when we have it.
Jim Butterfield is pretty amazing. I was reading The First Book of KIM and imagining what it would have been like for that to be my introduction to programming. He covers everything in a way that starts slow and builds naturally. His writing style is very conversational, almost like he is sitting there with you explaining what to do and why. I think that anyone with second grade reading skills would have no problem with it.
