Cannot Open Program In Emulator Through Commandline
I hope that this is not a silly question but I cannot open a program through the emulator using the prg argument.
My environment is Windows 10.
Here is my command argument: x16emu -prg "CC65Test.cx16" -run
I can rule out either the file been invalid or the file not been in the correct location, because I can start the emulator without arguments and the load the file through BASIC.
Also the error I am getting is: The error I am receiving is Cannot open CC65Test.cx16!
3 ideas: try not using the quotes around the name / try naming it CC65Test.prg / try using only lowercase letters in the filename
Still, it should probably work as is
Thanks for responding to my question.
I think my issue was that I was not running my command in the same directory as the emulator.
Let me be clearer:
This fails: C:\>x16emu -prg "CC65Test.cx16"
However this works:
C:\>x16emu -prg "c:\commander\CC65Test.cx16"
Also this works:
C:\Commander>x16emu -prg "CC65Test.cx16"
Let me be clearer:
However this works:
Also this works:
Yeah, that first command line is never going to work if your stuff is in "C:\commander". You either need to already be in the correct directory (via the CD command) or explicitly specify the path to the program and image file - as you discovered.
