MineX16
View File
This is a minesweeper clone for the Commander X16. It allows custom minefield sizes up to 38x24, with almost any amount of mines.
To start, load and run MINEX16.PRG.
Controls:
Main Game
Left click to reveal a tile
Right click to flag a tile
Click on the face to reset
Press space to open the configuration screen (will reset the minefield)
To exit, reset the machine (Ctrl-R on the emulator)
Configuration
Space to open and close
Use the + and - buttons next to each digit to change the width, height, and number of mines
Numbers are capped to a specific range; attempting to select an invalid value will set the number to its maximum or minimum value
Click any of the presets to set all of the numbers at once
Note: The game uses kernal functions to handle the mouse, so any weirdness is most likely caused by the emulator.
Submitter
Submitted
08/19/20
Category
