Direct vMem manipulation?
DoubleA
Post by DoubleA »
Wouldn't it be nice/helpful to directly manipulate vMem (copy/move/clear) with the help of a small but fast custom VERA routine? Without burdening the CPU to much?
One could even call it a blitter :-).
StephenHorn
Post by StephenHorn »
DMA (direct memory access). You're asking for DMA.
Maybe, but when I think of "Blitter", I think of a system that's purpose designed to move video pixels; it might use DMA to do that, but it's not just DMA. Aside from basic memory copies, the minimal thing a blitter needs to have is the ability to repeat an operation for multiple rows, so the simple add-copy-compare operation needs to be wrapped in an additional add-compare-add? step.
I can picture a series of gates in my head that will do that in one clock tick, but there's probably something I"m missing.
All this talk of VERA and her capabilities have made me really want to dig in to FPGA design. I remember being really fascinated with the logic gate simulator in my digital design class, and FPGAs seem like a natural extension of that.
DoubleA
Post by DoubleA »
That's the basic idea, one tick is as fast as it gets.
The other "Blitter" i had in mind was somehow crippled, because it had only access to slow (chip) ram. But with the X16, it's the other way round ...
And there's DMA and then the other DMA. This one would be "internal". Could be triggered "immediate" or "IRQ-controlled" or something else, as long as it stays strictly VERA internal.
VincentF
Post by VincentF »
The idea I have from your description is like a sort of programmable action to perform from inside the VERA chip, kind of like shaders for GPU ?
DoubleA
Post by DoubleA »
Kinda ? (but much simpler).
lamb-duh
Post by lamb-duh »
DMA is available to hardware connected to the expansion slots, right? Does hardware have direct access to video ram, and if so could that be done without interrupting the cpu?
DoubleA
Post by DoubleA »
What i suggested could be done without CPU or "external" DMA. Would be the same mechanism as initialising sprites, but for "blits". Strictly VERA internal.
BTW: How does VERA handle HSCROLL and VSCROLL? Just changes a pointer or moves vMem content?
StephenHorn
As far as I'm aware, it does not move VRAM content, that has never been a part of the emulator's implementation of HSCROLL and VSCROLL.
If I were to guess, it bit-shifts HSCROLL and VSCROLL by 7 bits and copies into internal 16-bit accumulators (representing 9.7 fixed point integers). Then as it draws, it increments the accumulators by HSCALE for each column and VSCALE for each row (which are 1.7 fixed point), and decides the "real X, Y" by reading the top 9 bits of the accumulators (the truncated integer portion).
Edit: Actually, this may be more than a guess, I seem to recall Frank has previously discussed this on Facebook, on a comment thread where someone wanted to change the basis value for scaling from 128 to 240, so as to provide finer-grained scaling, and suggested a relatively fast division-by-5 hardware design to try and make it possible. This seems to have been ultimately rejected. In fairness, I believe the HSCALE and VSCALE were originally only meant to provide power-of-2 scaling, and the VERA had already grown somewhat beyond its original design by taking on features like the PSG, so LUTs and Frank's own time may be at an extreme premium at this point.
Also remember that what finally killed the Gameduino V1.0 modification approach was contention between the 65C02 and the J1 coprocessor. A DMA blitter on an expansion card that reads via Port A and then writes back the modified data via Port B doesn't have that problem because it would be bus mastering ... when it controls the bus, it leaves the 65Cxx address and data lines in a high impedance tri-state and when it surrenders the bus, the 65Cxx is entirely in control.
So not only is it highly unlikely that they WANT to go for a classic 32bit+ system move with a Blitter, but there are reasons to expect it might introduce problems in getting the system up and running.
