Here is something I think I found out - Let me know if I am wrong
Tutorials and help articles.
waspentalive
Post by waspentalive »
Hi  Everyone!
If you are using the SDCARD image and you want to save a file over itself you need to use save "@0:filename"  but if you are using the host filesystem instead of an image file you cans simply use save "filename" and the file will be replaced. (at least with Linux)
