New demo uploaded: Blinkenlights
Blinkenlights
View File
A simple file that graphically shows the values of several registers in the X16 which change regularly -- for example, the top of the accumulator stack, and some of the I/O registers.
It's an attempt to replicate the "blinking lights" of systems that used to use big ol' LEDs to represent register contents, alarm bars, and whatnot.
The C source is here: https://github.com/bobbyjim/x16-blinkenlights
  • Submitter
  • Submitted
    08/16/21
  • Category
The display looks kind of Tetris-y right now.  I'd like it to look less like Tetris, and more like a bank of LEDs.
Any ideas?
Cyber
Post by Cyber »
Can you show example of LED bank you are talking about?
I imagine this...
Arduino Altair 8800 Simulator - Arduino Project Hub
or this
IMSAI 8080 replica
or this
PDP-11/70 Retrocomputing Build - Planet Geek!
Any ideas?
Try the circle character (shift Q), and use bright/dark versions of colors. (You'll probably have to modify the palette a bit.)
Yep, I was seeing the PDP-8 in my head.  I'll try circles.
I'm also wondering if there's additional semi-useless information that might be nice to see on this kind of eye-candy display.
Maybe I can also draw some nice PETSCII beveled lines to break up the space into logical areas.  Yeah, I'll try that too.
Here's a concept for the second iteration.  I'll try other colors as well, but red circles look very LED like, and the dark gray emulates "off" nicely.
Looking for more useless info to display.  Currently showing:
  • localtime
  • VIA #1 registers ($9f66 and $9f67 don't have any activity)
  • stack ($01d6 thru $01e5).
I suppose I could grab the registers.
OK, merged the changes, and updated the Downloads entry.
I added in a keyboard scan.
I also included the i/o status byte, because I had room for it.
