Banked ROM
Banked ROM
Hi all, just a quick question. Can the banked ROM at addresses $C000-$FFFF be banked out for RAM? I'm pretty certain the answer is no but I can't find where I read that now.
Banked ROM
Nope, not possible. Wouldn't give you much of an advantage anyway, except if you want to copy large amounts of data from one area in banked ram to another.
Plus, you'd have to deal with the reset and interrupt vectors which are hardcoded at the end of the 65C02's address space.
Banked ROM
Thanks, that's what I thought.
Since posting the question I went and re-watched "Building my Dream Computer - Part 2" and realised that it says ~40K LOW RAM quite clearly on the board. And I was about to post that I had answered my own question when I went down a bit of a rabbit hole...
The serial number on the low RAM memory indicates that it's a 128K chip (which doesn't mean anything if those higher addresses aren't connected). Of course I needed to see if maybe they were connected and spent way to much time trying to find traces from the back of the board to the MEMORY DECODE and BANK SEL chips. I couldn't find them (but I had fun trying) and came back here.
- StephenHorn
- Contact:
Banked ROM
The high RAM memory, 0xa000-0xbfff will be bankable. The prototype boards in Dave's videos probably date back to when banking was handled through one of the VIA controllers. Now it's on ZP address $00.
(As already answered, ROM memory 0xc000-0xffff will be bankable, but only to other ROM memory. That is now on ZP address $01.)
Edit: Low -> High. It's what I meant, honest. ?
Banked ROM
5 hours ago, StephenHorn said:
The low RAM memory, 0xa000-0xbfff will be bankable. The prototype boards in Dave's videos probably date back to when banking was handled through one of the VIA controllers. Now it's on ZP address $00.
I think you have that backwards.
- StephenHorn
- Contact:
Banked ROM
Banked Memory
The currently enabled RAM and ROM banks can be configured by writing to zero page locations 0 and 1:
Address | Description |
$0000 | Current RAM bank (0-255) |
$0001 | Current ROM bank (0-31) |
The currently set banks can also be read back from the respective memory locations. Both settings default to 0 on RESET. The upper three bits of location 1 are undefined.
https://github.com/commanderx16/x16-docs/blob/master/Commander X16 Programmer's Reference Guide.md#banked-memory
Edit: Doh, I meant High RAM.
