Suggestion for audio convertors
Yazwho
Post by Yazwho »
Hello! I don't suppose anyone can recommend an audio convertor that can output data that the Vera can take, eg 12,207Hz 8bit audio. Tto something like a wav file so I can process it? Either a PC app, or on a website?
The best I've found is around 16kHz. (or 16bit) Nothing where you can specify the sample rate \ bitrate exactly.
Any suggestions?
SlithyMatt
Post by SlithyMatt »
I use Audacity, and it works great for any bitrate you want. That's what I used to generate all the tracks for this demo:
Elektron72
Post by Elektron72 »
Go to File > Export > Export Audio... and select "Other uncompressed files" from the file type dropdown. Change the header to "RAW (header-less)" and select either "Signed 8-bit PCM" or "Signed 16-bit PCM".
kliepatsch
Post by kliepatsch »
One could also do the math how much one needs to pitch up a sample at, say, 20 kHz, so that it has the original pitch when being played back at the target sample rate.
If I am not mistaken, the pitch in semi tones should be
st = log_2(f_e/f_t) * 12,
where f_e is the sampling frequency you are exporting at, and f_t is the sampling frequency of your target platform. The log_2 gives the pitch in octaves. Multiply it by 12 to get semitones.
Does that make sense? ?
I use Audacity too. 12970 Hz stereo 16bit audio works pretty well, decent dynamic range and sound quality.
Edited to add:  The PCM audio buffer only holds 4096 bytes; it is a first-in first-out rotating buffer.  If it gets below 1kb of data it can trigger an interrupt, if you want to set it up that way.
An advantage of using a stereo 16 bit audio (4 bytes per sample) is that for any frequency that is a multiple of 5 (like 12970) there will be an exact number of bytes needed to play 1/20 of a second of audio.  For 12970 Hz, that's 2594 bytes every 1/20 of a second.  It's not exactly 12970 Hz, but it is so close that it would take about an hour of audio playback before you got out by a tenth of a second or so.
That 2594 is just a little over 60% of the size of the buffer, so you can load the first 1/20 of a second of audio, start playback, wait 1/60 of a second, load the next 1/20 second of audio, and thereafter load another 2594 bytes every 1/20 of a second; if it is timed just right the audio won't overflow or underflow the buffer and you'll get continuous playback.
Yazwho
Post by Yazwho »
Audacity it is!
Thanks,
