Silicon Motion graphics chip SM750
Get one of these and put it on an expansion card... ?
I saw it on Jeff Geerling.
It's a GPU designed for use in embedded systems, supports HD resolution.
Not likely. This is a PCI Express device; no way will it interface with an 8-bit 6502 bus without additional, complex hardware... by the time you're done, you may as well have just stuck a Raspberry Pi in there, instead.
Quite ... "designed for embedded systems" needs parsing to find out what kind of embedded system it is referring to. Nowadays the "embedded" system might be built around a 64bit x86 processor.
Indeed, a RPi would be easier to interface ... there's plenty of GPIO for an eight bit data port, five address lines for a pseudo register system, the R/W line, and a toggle bit for a circuit that holds the RDY line once the RPi is selected until the release bit is toggled. Other than the RDY hold circuit it would mostly be 3.3V/5V level shifters.
It does have an I²C interface, though. ?
Yes, I'd like to look at a datasheet to see whether that is a port for access by the controller or an I/O port for the controller to use. It seems like it could be the latter, since it also lists "GPIO", which would be a bit confusing as a way to describe an access port but could be a handy addition for the controller to use.
Falken
Post by Falken »
The oldest graphics chip that is still manufactured is the Matrox G200 according to my knowledge. But I guess even that one is already too advanced.
"Advanced" may be the wrong word, but the G200 is an AGP card, and that's designed to be coupled with an era-appropriate CPU that has an AGP bus. I can't imagine making that work with a 6502 without custom silicon.
For that matter, no true VGA chipset is going to work with a 6502. The bus interface and BIOS requirements alone are going to make VGA chipsets incompatible.
At best, you might make an 8-bit ISA VGA chip work, but you'd still have to write a custom BIOS and translate between the 6502 and the ISA bus... and the irony there is that the 6502 at 8MHz is about 3 times faster than the ISA bus at 8 Mhz, so you'd actually have to slow the CPU down to work with an ISA video card.
